I have checked my Rain8net Pro modules work and I can do the following;
The condition that test com works and mcsSP reads eeprom shows that communication is out of the issue pool.
But mcsSP can not use schedule or manual to operate zones / valves. Visually and in logs I see a manual start
for 2 minutes as a test indicate a ON condition on the zone / valve.
here is a test of R7 9:41
Calendar View of Zone History R7 : Rain8 Front Porch Drip A1: Area 1 Status 101% Today 9:41 AM for 15 mins
7/17/2013 9:41:27 AM R7 Rain8 Front Porch Drip OFF
7/17/2013 9:41:35 AM R7 Rain8 Front Porch Drip ON
but no zone / valve output of water.
Can mcs inhibit zone / valve on with a manual selection?
Where can I check those settings / that out?
(Setup- Hardware is configured as mcsSP Pro with Vcom 3.6.3 serial to IP
to an xs1000 IP to serial converter connected to rain8net modules 1 and 2
set to 4800 baud and using alternative telnet port 24 since port 23 is busy on HS2 ver xx.80
read and write eeprom values from mcsSP Pro
communications test operate the zones / valves briefly in a test sequence
rain8 demo works with the modules
debug log, see R7 show ON:
7/17/2013 9:41:32 AM 635096508925057671 | mcsSprinklers Debug | Sprinkler Valve R7 turned on with moisture at Calc=1.01-Meas=1.01/0 and ZonesPending=0.0.0.0.0.0.0.1
7/17/2013 9:41:32 AM 635096508925147676 | mcsSprinklers Debug | CommonExecX10, Rain8NetUPB HouseCode=., Device=R7, State=ON, rtoX10CollectionCount=0, iType=-1
7/17/2013 9:41:32 AM 635096508925147676 | mcsSprinklers Debug | CanSendItNow Queued for R7, queue size =1
7/17/2013 9:41:32 AM 635096508925517697 | mcsSprinklers Debug | AddAction R7=on, Dur=0, Path=5
7/17/2013 9:41:32 AM 635096508925517697 | mcsSprinklers Debug | LogValveAction R7=on, Path=2
7/17/2013 9:41:32 AM 635096508925517697 | mcsSprinklers Debug | Log Discrete INSERT INTO dR7 (SampleDate,Discrete) SELECT #2013-07-17 09:41:32# AS QT,1 AS Q1
7/17/2013 9:41:32 AM 635096508925697707 | mcsSprinklers Debug | OnCommand 12930 Was rtdZoneDeviceLastChange(7)=7/17/2013 9:41:32 AM, NowIs=7/17/2013 9:41:32 AM
7/17/2013 9:41:32 AM 635096508925717708 | mcsSprinklers Debug | AreaOn(0)=True
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(1)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(2)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(3)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(4)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(5)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(6)=False
7/17/2013 9:41:32 AM 635096508925847716 | mcsSprinklers Debug | AreaOn(7)=False
7/17/2013 9:41:32 AM 635096508925987724 | mcsSprinklers Debug | Cycle Active(0)=False, Anything On=True
7/17/2013 9:41:32 AM 635096508925987724 | mcsSprinklers Debug | bZoneIsRunning=,0,0,0,0,0,0,0,1
7/17/2013 9:41:32 AM 635096508925997724 | mcsSprinklers Debug | rtiAreaStartTime(0)=300,1500,1500,1500,1500,1500,1500,1500,1 500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1 500,1500,1500,1500,rtiAreaStartTime(1)=0,1500,1500,1500,1500 ,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500 ,1500,1500,1500,1500,1500,1500,1500,rtiAreaStartTime(2)=0,15 00,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,15 00,1500,1500,1500,1500,1500,1500,1500,1500,1500,1500,
7/17/2013 9:41:32 AM 635096508925997724 | mcsSprinklers Debug | rtbZoneWateredToday=True,False,False,False,False,False,False ,False,
7/17/2013 9:41:32 AM 635096508925997724 | mcsSprinklers Debug | rtiAreaNextStartTime=0,0,0,
7/17/2013 9:41:32 AM 635096508926267740 | mcsSprinklers Debug | rtiWaterTankLevel=0, rtiPreviousSiteWater=-8, rtiWaterTankLevelMax=0, rtiWaterTankLevelMin= 0, DeviceOn=True, bTankState=True, nTankLevel=0
7/17/2013 9:41:32 AM 635096508927037784 | mcsSprinklers Debug | PollRain8NetStatus StatusCount=0,IndexCount=1
7/17/2013 9:41:32 AM 635096508927047784 | mcsSprinklers Debug | NextTimerInterval=27296, MinNextTimerInterval=60
7/17/2013 9:41:32 AM 635096508929537927 | mcsSprinklers Debug | ManualEnable=False,False,False,False,False,False,False,True, Override=True, ASPStop=False, bTransitionToManualMode=False
7/17/2013 9:41:32 AM 635096508929797942 | mcsSprinklers Debug | bKeepZoneOn=False, bTurnOff=False, bTurnOffArea=False,False,False,False,False,False,False,False , Transition=False,PrevAutoMode=False,
Might be something simple- but I am not finding it.
Where can I email the developer? I do not see email address.
I have logs and .ini file that might help.
END
END
