I am running Pro (2.13.0.3/2.13.0.17 shows on page), and under Areas Setup, I do not see any options for water source and specifically where to set a water meter. I am finally getting around to installing my water meter, but for some reason I do not see where to configure it. Ideas?
Water supply config missing
Best guess is that you did your set via the interview and at that time you did not indicate any water measurement. If this is the case then there are two approaches available. One is to repeat that part of the interview by hovering your mouse over the interview step checkboxes and unchecking the setup for this. The other is enable all settings from the Other Page with expert mode checkbox at the bottom.
