Running HS3 with MCSSprinkers Pro, latest versions from the downloader (I know Pro is over spec'ed for my setup but I want ot hook in other sensors once I get the basics working).
I have three areas, with one zone/valve in each area
I have a master valve that needs to be on whenever any of the area/zonees are on. I have configured the master valve as a Pump and assigned it to each area on the area set up page
The valves themselves are simply ZWave devices with a House Code / Unit Code set up so I can address them from MCSSprinklers.
Here's my problem:
For some reason the Master Valve (pump) is turning On and Off every minute, see log below:
11/09/2014 18:20:10 Q152 Garage Master Valve ON
11/09/2014 18:20:11 Q152 Garage Master Valve OFF
11/09/2014 18:21:08 Q152 Garage Master Valve ON
11/09/2014 18:21:09 Q152 Garage Master Valve OFF
11/09/2014 18:22:08 Q152 Garage Master Valve ON
11/09/2014 18:22:09 Q152 Garage Master Valve OFF
I don't understand why this would be (it should only come on and off with the zones) and obviously this behaviour is stopping the PI from working.
Any help pointing me in the right direction of what I am doing wrong would be appreciated!!
Here's my problem:
