So I decided to start MCS for the season. First off I noticed that it could not serve clock2.swf. When I checked the directory both clock.swf and clock2.swf were missing (compared to a previous backup from last summer). I copied them back in and resolved that issue. Then when I go into the touch zone I get the following:
01/05/2015 6:55:20 PM mcsSprinklers RunList FormatScreen Line 930 Index and length must refer to a location within the string.Parameter name: length
01/05/2015 6:55:36 PM mcsSprinklers RunList FormatScreen Line 930 Index and length must refer to a location within the string.Parameter name: length
01/05/2015 6:56:36 PM mcsSprinklers RunList FormatScreen Line 930 Index and length must refer to a location within the string.Parameter name: length
When you select the center picture in the touch zone, you don't get in info on the left screen - I guess this is the RunList error above. You only see it when you click on one of the dots below.
The touch area center screen is blank as well..
No changes were made to my HS2 running on SSD drive. Can you help with this issue going on here?
Rob
Rob
