Replacing Rain8net with Relay8net
  • Replacing Rain8net with Relay8net
    I'm removing a Rain8net controller, and replacing it with a Relay8net.
    The Rain8 worked fine, but I can't configure the Relay8. When setting the address it times out and a message pops up asking "is there a controller attached?"
    I'm using the same plug-in as I did for the Rain8. Is there a different one?
    The serial port is worknig fine- the led on the controller is on steady.
    Are you selling your Rain8net?
    Jon
      I can't think of any reason it wouldn't work, as long as your using the same physical com port as you were with the rain8, unless the unit or power supply is defective.
      Marty
      XPpro SP3 /w HS Standard 2.5.0.80, HSTouch Server - 1.0.0.70, HSTouch Client 1.0.0.73 HSTouch Android - 1.0.0.2, HSTouch iPhone - 1.0.0.2
      Playing with HS3 a bit but it's just play at this point.
