Issues with RainNet8 Plugin
  • Issues with RainNet8 Plugin
    Referencing Larry's Plugin:
    Plugin doesn't communicate with Irrigation controller. Turned on debug and noticed that it is opening COM1, although I had set it to COM22. Verified that COM22 is working by using HST's plugin. I tried to shut it down and the plugin crashed.
    Following is the log....
    Aug-13 11:14:15 AM Error Posting back to plugin web page Rain8Net_Config: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
    Aug-13 11:14:13 AM Error Posting back to plugin web page Rain8Net_Config: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
    Aug-13 11:14:08 AM Warning Cannot access remote plugin Rain8Net
    Aug-13 11:13:30 AM Error Calling SetIOMulti in plugin Rain8Net:Object reference not set to an instance of an object.
    Aug-13 11:10:38 AM Warning Plugin Rain8Net is not responding but it is still running, not restarting yet.
    Aug-13 11:10:30 AM Error Calling SetIOMulti in plugin Rain8Net:Object reference not set to an instance of an object.
    Aug-13 11:07:30 AM Rain8Net Debug Rain8Send()...Sending Byte3:--> &H31
    Aug-13 11:07:30 AM Rain8Net Debug Rain8Send()...Sending Byte2:--> &H1
    Aug-13 11:07:30 AM Rain8Net Debug Rain8Send()...Sending Byte1:--> &H40
    Aug-13 11:07:30 AM Rain8Net Debug Entering Rain8Send()....
    Aug-13 11:07:30 AM Rain8Net Debug SetRain8Zone()..Sending 3-Bytes-->Rain8Send( Mode = &H40, Unit = &H1, On + Valve: &H31 )
    Aug-13 11:07:30 AM Rain8Net Debug SetRain8Zone()...Unit: 1 ...Name: ...Zone-1 - ON
    Aug-13 11:07:30 AM Rain8Net Debug SetRain8Zone()...ZoneName = , iValve value = 1.
    Aug-13 11:07:30 AM Rain8Net Debug Entering SetRain8Zone()....
    Aug-13 11:07:30 AM Rain8Net Debug Entering SetIOMulti()....
    Aug-13 11:07:30 AM Device Control Device: Rain8Net Rain8Net to On (1) by/from: CAPI Control Handler
    Aug-13 11:06:20 AM Rain8Net Debug *********************************************
    Aug-13 11:06:20 AM Rain8Net Debug Rain8Net Re-Create DEVICES button pressed
    Aug-13 11:06:16 AM Rain8Net Debug Entering CreateDevices()....
    Aug-13 11:06:16 AM Rain8Net Debug Entering...InitDevices().
    Aug-13 11:06:16 AM Rain8Net Debug LoadConfigSettings()....
    Aug-13 11:06:16 AM Rain8Net Debug Entering DeleteMyDevices()....
    Aug-13 11:06:16 AM Rain8Net Debug Entering web_Config---postBackProc()....
    Don
    Bump...
    Don
      Please post the FILE Rain8Net.log after enabling Debug.
      -Larry
      A member of "The HA Pioneer Group", MyWebSite
      Plugins:
      VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
      Hardware:
      Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
        PHP Code:
        8/15/2015 10:55:21 AM ~***************************************
        8/15/2015 10:55:21 AM ~Rain8Net Debug Enabled.
        8/15/2015 10:55:21 AM ~Rain8Net Debug Logging toC:\HomeSeer HS3\Logs\Rain8Net.log.
        8/15/2015 10:55:21 AM ~Rain8Net HS-Version3.0.0.194
        8
        /15/2015 10:55:21 AM ~Rain8Net Plug-In Version3.0.0.1
        8
        /15/2015 10:55:21 AM ~Rain8Net Plug-In Server IP Address127.0.0.1
        8
        8/15/2015 10:55:21 AM ~About to read config file entries
        8
        /15/2015 10:55:21 AM ~LoadConfigSettings()....
        8/15/2015 10:55:21 AM ~Entering RegisterWebPage()....
        8/15/2015 10:55:21 AM ~Entering RegisterHelpPage()....
        8/15/2015 10:55:21 AM ~Entering InitRain8Net()....
        8/15/2015 10:55:21 AM ~Entering ComPort()....
        8/15/2015 10:55:21 AM ~ComPort is Initializing....
        8/15/2015 10:55:21 AM ~COM22Opened Successfully.
        8/15/2015 10:55:21 AM ~Rain8Net initialize the ComPort properly.
        8/15/2015 10:55:21 AM ~............................................................
        8/15/2015 10:55:21 AM ~InitIO()-Initialized Rain8Net Plugin successfully
        8
        8/15/2015 10:55:34 AM ~Entering web_Config GetPagePlugin()....
        8/15/2015 10:55:34 AM ~Entering web_Config---BuildConfig()....
        8/15/2015 10:55:34 AM ~Entering BuildDropList()....
        8/15/2015 10:55:34 AM ~Entering BuildTextBox()....
        8/15/2015 10:55:34 AM ~Entering BuildButton()....
        8/15/2015 10:55:48 AM ~Entering web_Config---postBackProc()....
        8/15/2015 10:55:56 AM ~Entering web_Config---postBackProc()....
        8/15/2015 10:55:56 AM ~Entering  DeleteMyDevices()....
        8/15/2015 10:55:56 AM ~LoadConfigSettings()....
        8/15/2015 10:55:56 AM ~Entering...InitDevices().
        8/15/2015 10:55:57 AM ~Entering  CreateDevices()....
        8/15/2015 10:56:00 AM ~*********************************************
        8/15/2015 10:56:00 AM ~Rain8Net Re-Create DEVICES button pressed
        8
        8/15/2015 10:57:23 AM ~Entering SetIOMulti()....
        8/15/2015 10:57:23 AM ~Entering SetRain8Zone()....
        8/15/2015 10:57:23 AM ~SetRain8Zone()...ZoneName Zone 8iValve value 0.
        8
        /15/2015 10:57:23 AM ~SetRain8Zone()...Unit...NameZone 8 ...Zone-ON
        8
        /15/2015 10:57:23 AM ~SetRain8Zone()..Sending 3-Bytes-->Rain8SendMode = &H40Unit = &H1On Valve: &H30 )
        8/15/2015 10:57:23 AM ~Entering Rain8Send()....
        8/15/2015 10:57:23 AM ~Rain8Send()...Sending Byte1:--> &H40
        8
        /15/2015 10:57:23 AM ~Rain8Send()...Sending Byte2:--> &H1
        8
        /15/2015 10:57:23 AM ~Rain8Send()...Sending Byte3:--> &H30
        Don
          I need the complete file, this only shows the initialization.
          -Larry
          Plugins:
          Hardware:
            This is the complete file. When I attempt to disable the plugin it locks up homeseer. I have reloaded the plugin, enabled the plugin, enabled debug, and tried to open and close some valves. I couldn't get back to the config page to disable the debug, so that is all there is. Please let me know if there is anything else you would like me to try. I've included the latest debug.
            Thanks.
            Don
              I noticed the version of plugin you are using is for HS2 attached is a HS3 version which was sent to updater, but things work a little slow up there and sometimes the Email filters eliminate attachments.
              Try this one and let me know.
              -Larry
              Plugins:
              Hardware:
                Really? Well, I blew that! :-)
                I'll give it a spin. Thank you.
                Don
                  No problem, hope this version works for you. Please let me know if there are any issues. The email filters at HS are really getting to be a pain. They finally gave me another address to send to, so hopefully updates find their way to the updater.
                  -Larry
                  Plugins:
                  Hardware:
