HSPI_RainMachine has stopped working
  • HSPI_RainMachine has stopped working
    When I reboot my Win7 machine or sometimes with a restart of HS3 I get an error dialog screen that says the HSPI_RainMachine has stopped working. Here is the detail from that screen.
    Problem signature:
    Problem Event Name: CLR20r3
    Problem Signature 01: hspi_rainmachine.exe
    Problem Signature 02: 1.0.0.1
    Problem Signature 03: 5c049086
    Problem Signature 04: HSPI_RainMachine
    Problem Signature 05: 1.0.0.1
    Problem Signature 06: 5c049086
    Problem Signature 07: 54
    Problem Signature 08: 0
    Problem Signature 09: System.NullReferenceException
    OS Version: 6.1.7601.2.1.0.256.48
    Locale ID: 1033
    Additional Information 1: 0a9e
    Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
    Additional Information 3: 0a9e
    Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
    Read our privacy statement online:
    http://go.microsoft.com/fwlink/?link...8&clcid=0x0409
    If the online privacy statement is not available, please read our privacy statement offline:
    C:\Windows\system32\en-US\erofflps.txt
    Here is what I have seen with a restart of HS3 in the log when I try to control a zone: Calling SetIOMulti in plugin RainMachine:Object reference not set to an instance of an object.
    I don't see anything else in the HS3 log about the plug-in not working.
    I think this has been going on ever since I installed the plug-in. I haven't had time to investigate it until now.
    Problem signature:
    Locale ID: 1033
    Thanks for the report. I'll take a look and see if I can spot anything in the code that would cause that. It's probably something simple that I'm not checking when it first starts up.
    Bob Paauwe
    ISYInsteon Plug-in
    http://www.bobsplace.com/ISYInsteon/
      Were you able to find anything regarding this issue?
        I haven't found anything yet that triggers this type of failure. I did find a different problem that seems to be related to the 1st generation hardware. Is it possible that you're trying to control a zone when the plug-in isn't able to authenticate with the RainMachine?
        Bob Paauwe
        ISYInsteon Plug-in
          I need to do some more testing on this. Are you saying that if the plug-in can not authenticate that the plug-in can interrupt the HS3 roboot process?
            No. Am I mistaken about what you reported? My understanding was that the plug-in crashed, not HS3. Attempting to control a zone when not authenticated may be what causes the plug-in to crash. That should be an unlikely scenario, but could happen if the password is changed on the RainMachine and not updated in the plug-in or if the plug-in is unable to contact the RainMachine. I need to do some more investigation and will add some checking to prevent that.
            Plug-ins should not be able to crash HS3, if they do, it's probably a bug in HS3 that needs to be addressed.
            Bob Paauwe
            ISYInsteon Plug-in
