I have a HD16 with a flow meter attached. Is there a way to read the associated values (leakage, etc.) in the HS plugin?
Any way to get flow meter information in plugin?
https://support.rainmachine.com/hc/e...Touch-HD-12-16
I was pleasantly surprised the RainMachine supports a flow meter. Would be great if there was a way in the HS Plugin to read both the used gallons as well as leakage...
Can you be more specific about how you want to use these?
I see in the API that they added flow clicks to the watering log details report (which I don't currently look at) and added last leak detected to the current restrictions. But they have not documented what these look like in the returned data.
