Rain8Net pro rain/moisture sensor
  • Rain8Net pro rain/moisture sensor
    Does any one know what rain/moisture sensor is compatible with the rain8Net pro. Hooking this up to an HAI system and need to shut down zones when ground is moist enough.
    Hi,
    did you ever work this out?
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
      Originally posted by Raptor View Post
      Hi,
      Raptor
      These sensors will not allow the valves to be turned on while they are wet/moist. I have a rain sensor hooked up to an analog input board, then use some rules in HS to only run an irrigation event if the rain sensor has not detected rain, works well!
