rain8 stops responding after a day
  • rain8 stops responding after a day
    My rain8 module quits after a day or two. I have to constantly power cycle the device for it to work. In the log I get error message saying. Is there a controller at address 1. Does anyone have any idea why this happens? Usb ports are set to not go to sleep. Thanks for any help.
    If I restart the HS computer it still does not work I Have to power cycle the moduel. Could this be a defective module or is there a setting somewhere that I am missing?
      Last time I had something like that my cable was bad. I have the rj11 and adapter type.
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
        I have this same problem, although not on a daily basis.
        The work-around I came up with is to plug the Rain8 power into an appliance module and use BLLogMonitor plug-in. When the error occurs, the log monitor triggers an event that turns the appliance module off for a couple of minutes and then back on.
        It has worked quite well for me.
        As far as the cause, I don't know.
          Mine does the same thing everytime HS restarts. If HS restarts then I have to power cycle the Rain 8 module for it to work.
            Something for you guy with the same issue to try.
            I am only using 3 of the 8 zones. If I leave zone 4-8 on all the time my controller has been working for 2 weeks straight. I normally get a day or 2 before I have to reset it. I would be curious to see if it works for you as well.
              Same problem for over a year
              I had the same problem for over a year, made me crazy. If you are hard wired from your CPU to the rain8net, make sure your data cable is not routed alongside or across any other power source ( a 220v romex in my case), the electrical field will from time to time knock out the programming. I re routed my cable and it has operated flawlessly since.
              HS3Pro on Windows 10
              One install with 2 Ethernet Z-nets
              2nd install with 1 Zstick
              300 devices, 250 events, 8 scripts
              5 CT-100 tstats
              Serial IT-100 interface to DSC Panel with 8 wired zones
              18 Fortrezz water sensors & two valve controls
              Serial Rain8Net Pro with 8 zones
                Good to hear your ok!!!
                Hector
                Win.2003 OS, HS3
                  Thanks. Yeah, it was an awful experience, but the simple cable re route fixed it all.
                  5 CT-100 tstats
