Uninstalling Rainrelay plugin ?
  • Uninstalling Rainrelay plugin ?
    How do I uninstall this plugin? There no "X" icon next to name to uninstall in HS3?
    Hector
    Win.2003 OS, HS3
    MyTrigger,ACRF2,W800,Zwave
    AP800,Honeywell Stat
    Hi Hector,
    You can just stop the plugin and then delete the "HSPI_Rain8.exe" file in the root of your HS3 directory.
    Cheers
    Al
      Originally posted by sparkman View Post
      Hi Hector,
      Cheers
      Al
      Thks for your response , but will that remove all of the files pertaining for that plug-in?
      Hector
      Win.2003 OS, HS3
        Look in the add/remove or programs and features for an installer. Many new plugins have installers to remove them. I'm not sure if this one does.
        -Rupp
          I thought the installer option was eliminated in HS3
            I guess I need to clarify then some plugins in HS2 have add/remove. In HomeSeer 3 there a red X next to plugins to remove them.
            -Rupp
              You add/remove program in window?
              Hector
              Win.2003 OS, HS3
                Is this for HS3 or HS2? If HS2 check to see if this plugin had an installer listed in the control panel add/remove programs or the programs and features option.
                -Rupp
                  This is for HS3.
                  Hector
                  Win.2003 OS, HS3
                    Then you use the red X beside the plugin to remove it.
                    -Rupp
                      there is no button..... and theres nothing in the plugin config page either .
                      Hector
                      Win.2003 OS, HS3
                        No, to get rid of it all you need to delete the following:
                        1. HSPI_Rain8.exe in HS3 root
                        2. Rain8 directory in HTML
                        3. rain8.ini in Config
                        Like I said, stop the plugin and delete the file
                        Cheers
                        Al
                          Thk you Sparkman that did it.
                          Hector
                          Win.2003 OS, HS3
                            Wow all of your plugins have the red X but that one. I wonder if it was because you hadn't disabled the plugin.
                            -Rupp
                              I did disable it back and forth it just said the same.... The plugin didn't work with the rain8pro, I tried blades ver. Worked right off the bat, with no issues. It's even better because when initializing the plugin it sends a message to the controller to know if it's there.
                              Hector
                              Win.2003 OS, HS3
