HS3 issues using Rain8Pro
  • HS3 issues using Rain8Pro
    Summer is closing in and I once again wanted to get my Rain8 Pro module up and running using HomeSeer3, but it fails.
    No error though.
    Steps taken:
    1 activate plugin
    2 configure plugin for 1 master & 4 zones
    3 test plugin by activating a zone.
    Now these steps are working fine. The problem occurs when I pres the next capi action. Now nothing happens.
    mai-23 19:24:46 Device Control Device: Not Set Not Set IO1 to Off (4) by/from: CAPI Control Handler
    mai-23 19:24:41 Device Control Device: Not Set Not Set IO1 to On (3) by/from: CAPI Control Handler
    mai-23 19:24:31 Device Control Device: Not Set Not Set IO1 to Off (4) by/from: CAPI Control Handler
    mai-23 19:24:27 Device Control Device: Not Set Not Set IO1 to On (3) by/from: CAPI Control Handler
    mai-23 19:24:18 Plug-In Finished initializing plug-in Rain8
    It's irrelevant what first action I'm doing. after restart of plugin.
    So if I disable the plugin and enable it again I can issue one action. E.G Pull and all statuses are updated, but when I later press on for one zone nothing happens.
    previously my setup have been working ok using HS2, Please advice, I want to get HS3 up and running.
    Yikes, I'm about to transition my R8P to HS3. Does it work?
    HS3Pro on Windows 10
    One install with 2 Ethernet Z-nets
    2nd install with 1 Zstick
    300 devices, 250 events, 8 scripts
    5 CT-100 tstats
    Serial IT-100 interface to DSC Panel with 8 wired zones
    18 Fortrezz water sensors & two valve controls
    Serial Rain8Net Pro with 8 zones
      I could not get it to work so I ended up with another plugin.
        What plug in? Are you using the R8P hardware?
        5 CT-100 tstats
          I ended up with mscSprinkler plugin. This was the only one I could get working stable. It's a bit more pricy but it worked and the author was quick to do some adjustments when needed.
          Yes I use the R8Pro hw.
