HomeSeer Rain8 / Relay8 3.0.0.6
  • HomeSeer Rain8 / Relay8 3.0.0.6
    Successfully used this plug in to control a Rain8net Pro Master Module. Something happened and now I can not turn / off outputs. have tried enabling / disabling plug in / changing ports to the usb connected device. Would love some ideas?
    System Information
    Current Date/Time: 3/1/2016 11:20:02 AM EST
    HomeSeer Version: HS3 Pro Edition 3.0.0.208 (Linux)
    HomeSeer: Is Registered
    System Uptime: 0 Days 0 Hours 24 Minutes 25 Seconds
    User Name and Access Level: default (Admin)
    LAN IP Address: 192.168.0.87 (hometrollerSEL)
    Client IP Address: 192.168.0.94 (192.168.0.94)
    External IP Address: 24.154.167.39 (static-acs-24-154-167-39.zoominternet.net)
    Network Adapter: HomeSeer Adapter -> Loopback Address (localhost) IP: 127.0.0.1
    Web Server Port: 80
    Number of Devices: 122
    Number of Events: 95
    Event Last Ran: 4 - Inputs - Manual Activation : Sequence #1, Ran at 3/1/2016 10:43:55 AM
    Number of unique event scripts used: 0
    Plug-Ins Enabled: Z-Wave:,HSTouch Server:,UltraGCIR3:,Global Cache:,UltraNetCam3:,ADIO-100:,PLCBUS:,PLCBUS:test,EasyTrigger:
    Modules/Threads: 42 Modules, 66 Threads
    HomeSeer Memory Used: 95 Mbytes
    Plug-In Memory Used:
    error is as follows
    I get the following error when I attempt to turn on one of the devices.
    Mar-01 11:01:16 AM Device Control Device: Not Set Not Set IO1 to On (3) by/from: CAPI Control Handler
