rnbHydra: Current Version: 3.0.0.6
This topic is closed.
This is a sticky topic.
    rnbHydra is a plugin designed to bring together the power of two of the most advanced systems for the smarthome: Hydrawise and HomeSeer. Hydrawise is the Industry-leading technology by Hunter Industries giving you the most powerful Wi-Fi irrigation control solution on the market. With this plugin, you can now integrate Hydrawise into your smart home giving you total control over your irrigation.
    Link to HomeSeer Store: https://shop.homeseer.com/collection...plugin-for-hs3
    • Status reporting of your irrigation controller and zones
    • Start/Stop/Suspend your irrigation
    • Allows Homeseer to trigger events on Hydrawise events & errors
    • Hydrawise Wi-Fi Controller (by Hunter)
    • Internet Access (both HS4 and Hydrawise)
    Userguide is here: rnbHydra - Userguide
    Overview video is here: https://youtu.be/pDq7OAXg5SA
    Setup video is here: https://youtu.be/wbRjgt8iNKA
    Support/Issues/Bugs/Enhahcements
    I utilise a simple issue tracking system for issues/bugs/enhancements with the main reason to ensure I do not miss any issues raised.Issues can be raised from directly within the plugin (preferred method) or issues/bugs can be raised directly at this link.
    Version History
    • 3.0.0.6 (24 Aug 2020)
      • Bugfix: Fix for unauthorized status sending plugin into enable/disable loop
    • 3.0.0.3 (24 Aug 2020)
      • Bugfix: Polling service may go into error and stop
    • 3.0.0.2 (12 Aug 2020)
      • Bugfix: Start All Zones was not starting zones unless a custom time had been entered
    • 3.0.0.1 (09 Aug 2020)
      • Zone names updated to start with controller name after initial install to allow natural grouping
      • New Device added to allow single device manage a controller and zones
      • Error in custom run times for events and devices fixed (custom run timers were incorrectly taken as seconds)
    • 3.0.0.0 - Initial Release (31 July 2020)
