rnbHydra is a plugin designed to bring together the power of two of the most advanced systems for the smarthome: Hydrawise and HomeSeer. Hydrawise is the Industry-leading technology by Hunter Industries giving you the most powerful Wi-Fi irrigation control solution on the market. With this plugin, you can now integrate Hydrawise into your smart home giving you total control over your irrigation.
Link to HomeSeer Store: https://shop.homeseer.com/collection...plugin-for-hs3
Userguide is here: rnbHydra - Userguide
Overview video is here: https://youtu.be/pDq7OAXg5SA
Setup video is here: https://youtu.be/wbRjgt8iNKA
Support/Issues/Bugs/Enhahcements
I utilise a simple issue tracking system for issues/bugs/enhancements with the main reason to ensure I do not miss any issues raised.Issues can be raised from directly within the plugin (preferred method) or issues/bugs can be raised directly at this link.
Version History
- Status reporting of your irrigation controller and zones
- Start/Stop/Suspend your irrigation
- Allows Homeseer to trigger events on Hydrawise events & errors
- Hydrawise Wi-Fi Controller (by Hunter)
- Internet Access (both HS4 and Hydrawise)
Version History
- 3.0.0.7 (11 Dec 2020)
- Bugfix: Updated API call due to updated API structure
- 3.0.0.6 (24 Aug 2020)
- Bugfix: Fix for unauthorized status sending plugin into enable/disable loop
- 3.0.0.3 (24 Aug 2020)
- Bugfix: Polling service may go into error and stop
- 3.0.0.2 (12 Aug 2020)
- Bugfix: Start All Zones was not starting zones unless a custom time had been entered
- 3.0.0.1 (09 Aug 2020)
- Zone names updated to start with controller name after initial install to allow natural grouping
- New Device added to allow single device manage a controller and zones
- Error in custom run times for events and devices fixed (custom run timers were incorrectly taken as seconds)
- 3.0.0.0 - Initial Release (31 July 2020)
