Date stamp does not update
  • Date stamp does not update
    I am testing the PI at the moment. The time stamps of the child devices do not update. The Rachio was watering today, the totals and last runtime seem to have updated, as has the last watered, but nothing else, they all have a time stamp 21/6/19
    Also the next watering, still showing as 22/6/19, that does not seem to update at all
    Can you please clarify the issue you are reporting. What devices in the screenshot should have updated that did not?
      Last watered has updated (today), but last duration, total runtime and max runtime have updated the value (i think, have to check after next run), but not the date stamp.
      Also the Rachio1 ScheduleRule1 StartDate, ist still on the 22nd, shout that not contain the next scheduled run (25th for me, on flex daily)
        The total watering time and max time are not updating at all (values and timestamp), there are other devices too which do not update. I uninstalled the PI, and deleted all the devices. I reinstalled the PI. The api key was still there though. I did try entering a wrong key, and a restart, then entering the right key again. Some devices still do not update.
          I am not seeing some of the values in the data returned from Rachio. I'll make a post on their support site sometime this weekend. I'll be able to do this after I run my sprinklers tomorrow while in debug.
            Is there any update on this ? It seems that most child devices do not update, the last watered seems to work most of the time, the others do not seem to update. What I would like to see is the next scheduled watering. That with a reliable last watered and watering time. If thats not possible, I dont think I have much use for the PI.
            I have 2 weeks trial left, and would be happy to test/debug whatever is needed
              Mine have never worked. He might say that they change the API, but those accumulator don't do anything, never have.
              Blair
              HomeSeer: HS3 Pro 3.0.0.548
              Hometroller S6 | Devices: 832 | Events: 211
              Plug-Ins: Z-Wave .252 | HSTouch | RFXCOM | UltraRachio3 | Sonos
              BLLAN | BLPLEX | BLLOCK | NetCAM | Global Cache Pro | Blur-Iris4
                I determined the values for those devices are in the API output, but are not actually changing between runs and therefore the device last update date/time does not change when being updated. I'll update the plug-in to use the lastWateredDate for the timestamp of those devices. I'll reply here when it's been posted to HomeSeer.
                  I made quite a few updates to the plug-in. The minimum refresh interval was changed from 1 to 2 minutes. When the Rachio is watering, the update interval is automatically set to every minute. When it's done watering, the update interval gets set back to the update interval specified in the options. The following HomeSeer devices will have their date/time updated based on the last watered date/time:
                  1. Rachio Zone Last Watered
                  2. Rachio Zone Last Duration
                  3. Rachio Zone Total Runtime [I removed the date/time update for this device because it's based on a schedule]
                  4. Rachio Zone Max Runtime [I removed the date/time update for this device because it's the max runtime a zone can run]
                  I'll post the update to HomeSeer Tomorrow after I let it run for a day.
                  Ultrajones
                    Ok that sounds good. Is there anything in the api to retrieve the next scheduled run for each zone ?
                      UltraRachio3 HSPI version 3.0.7164.18799 was submitted to the HomeSeer updater. It should be available within a few days for install.
                        The next schedule water time it not available via the Rachio API. Please go to their message board API section and make sure you request it.
                          Yes I will do that, so far their support has been pretty good. I'll download the new version as soon as its available in the updater.
                            I have posted a message on the Rachio forum about adding the next scheduled watering to the api. Looks as if it is implemented already, here is the response I had:
                            The zoneState for each zone includes a nextRun attribute with the time it’s next scheduled to run.
                            Here is a simple perl script that displays this info for the first controller in the first location on your account. Edit for your email and password before running.
                            I’m curious how you will use this data in your automation.
                            #!/usr/bin/perl
                             use LWP::UserAgent;
                             use JSON;
                             $user = 'me@mydomain.com';     # replace with the email address for your Rachio account
                             $pass = 'mysecret'             # replace with your Rachio account password
                             sub doreq {                     # print error and exit if request unsuccessful
                                 my ($name, $resp) = @_;
                                 return $resp->content if $resp->is_success;
                                 my $err = $resp->content;
                                 print "Request for $name failed: $err\n";
                                 exit(1);
                             $ua = LWP::UserAgent->new();
                             #$ua->proxy(['http', 'https'], 'http://127.0.0.1:8888/');
                             # get config data
                             $cfg = decode_json(doreq('config', $ua->get('https://app.rach.io/env.json')));
                             # log in and get access token
                             $token = decode_json(doreq('login', $ua->post("$cfg->{AUTH_SERVICE_URL}/token",
                                                              [ 'grant_type' => 'password', 'username' => $user, 'password' => $pass,
        'client_id' => $cfg->{CLIENT_ID}, 'client_secret' => $cfg->{CLIENT_SECRET} ])))->{access_token};
                             # get first device associated with this account
                             $devid = decode_json(doreq('device', $ua->get("$cfg->{API_URL}/location/listLocations/true", 'Authorization' => "Bearer $token")))
                                 ->{locationSummary}->[0]->{location}->{deviceId}->[0];
                             # get and display zone data
                             $listzones = doreq('get zone list', $ua->get("$cfg->{API_URL}/device/listZones/$devid", 'Authorization' => "Bearer $token"));
                             print $listzones;
                              #!/usr/bin/perl
                              use LWP::UserAgent;
                              use JSON;
                              exit(1);
                              # get config data
                              print $listzones;
                              Thanks for posting this. I'll add a new HomeSeer device to reflect the next scheduled run date/time.
