Devices not fully created
    Hi, I just installed the plug-in this morning and it has created the devices but doesn't seem to be configuring them correctly. Please see the screen shots;
    It seems to be communicating with Rachio.
    I am seeing some odd messages in the log that stop after disabling the plug-in;
    Aug-03 11:00:31 AM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object.
    Aug-03 11:00:28 AM HSTouch Server Warning Exception on Value Change callback: Object reference not set to an instance of an object.
    Aug-03 11:00:27 AM Error Exception saving grammar data to file C:\Program Files (x86)\HomeSeer HS3\Grammar\Grammar_Data_FOREMAN-TOUCH#Default.hs : The process cannot access the file 'C:\Program Files (x86)\HomeSeer HS3\Grammar\Grammar_Data_FOREMAN-TOUCH#Default.hs' because it is being used by another process.
    Stan
    Another user reported a similar issue, but I don't recall what the fix was. Are you running the UltraRachio3 HSPI on a Linux?
    Ultrajones
      Running on windows 7.
        Anyone else having this issue lately with the install?
        I know it was posted that multiple controllers were supported but just checking to confirm as well.
        I have two 16 zone controllers.
          I have a 16 zone controller. Can you please try clicking the "Show All" button on the View > Device Management web page to see if they appear. If they do not, then please enable debug and sent me the output.
          Enable debug from PLUG-INS > UltraRachio3 > UltraRachio3 > Options > Application Options > Logging Level > Debug
          Restart the plug-in, then let it run for about 5 minutes. Disable debug. Now locate the ultrarachio3_hspi_debug.log file in HomeSeer's root directory and either post it here or send it to ultrajones@hotmail.com.
          Ultrajones
            Sorry, I thought I had replied to this several days ago.
            After the last restart of the plug-in I let it sit until the next morning and it updated the devices.
            I was wondering if the Zone names will update or do i need to update them manually?
