ACRF2 Plugin version: 1.1.3226.27426
I've used the remapping of housecodes with offsets for motion sensors and Palmpads extensively. I need to add another Palmpad, mapping L to R for 'remote' with an offset of 64 for use in my garage. I've used all the unit codes from 1 to 63 already. There is a problem however in that the plugin seems to be limited to 64 units per housecode. There are no log errors.
Most other housecodes are already assigned to other purposes so I've hit the wall here. I'd assumed all this time I'd be good to go all the way to 96. In addition, I'm quickly running out of unit codes for motion sensors (HC M).
Is there any way around this (ie. an updated plugin) other than resorting to the use of a new house code?
