Duplicate RF triggers when using W800 and MR26a at the same time.
This topic is closed.
It's been a while since I used the ACRF2 plug-in (I've changed my setup and no longer needs it), but I do seem to remember that you are able to ignore certain X10 commands.
If this is the case then you might be able to ignore those particular codes that the MR26 is also picking up? Although you might have to be clever about how you partition your setup so that you only have certain house codes in one end of the house?
Regards
NicolaiNicolai L
It should handle this just fine. The data transmitted from the W800 and MR26a are different, but decode to the same thing.
If you do a "generate error report log" from the main configuration screen it will contain more detail about the exact timing of the signals and more info about how they are being handled. You don't need to change the logging level or anything. Just make sure you have had at least one occurrence of the problem (best to have one just before you generate the log).
Just send me the log file and I'll take a look.
Jon
Jon Ort
JonOrt@The--Orts.com
(Remove the dashes in the address, spam is getting out of hand)
