A check box that would append which receiver #, received the data (IE 1 or 2 or 3.. ..) to the "Type" column of the hs "Status" page.. presently it could help me debug my rfxcom issue. It appears that my Oregon sensors have communication errors (All at the same time.) It would be very helpful to see if the rfxcom is receiving any of the other 433mhz devices.. I could also see other uses like maybe getting some idea of coverage from each receiver.. If more than 1 receiver receives than may the append could be in order received (IE 1-6-3). Example presently the status column reads like this "ACRF2 Oregon Temperature" and if the option check box was checked that line would read something like this "ACRF2 Oregon Temperature 1" simple or if possible "ACRF2 Oregon Temperature 1 6 3" complex.. thoughts ??
Feature request..
This topic is closed.
Originally posted by Wadenut View PostI think Debug Logging would provide the information you're looking for. I've found using this under similar circumstances to yours to be surprisingly helpful.
