the plug in has drop downs for all the com ports, but i am usb into the pro 100. how do i configure so ACRF can recognize the w800 hardware?
how config w800 usb with HS?
This topic is closed.
Hi
Connecting it is still a com port from the plugin's perspective. USB devices typically present themselves to the computer as a virtual com port ...COM1:, COM2: etc
Just plug the W800 in and watch for the messages in the windows icon tray (lower right) to see when its configured successfully.
Then look in windows device manager, you will see a LPT and COM Ports drop down. It will show you the virtually connected com ports. In the plugin configuration, pick the one that you are already not using for other things, and you should be all setPaul
