Can't get BC4 to send any IR
  • Can't get BC4 to send any IR
    I just got my BC4 configured on HS. I can get to its built in webpage, and gave it a static IP. I have it setup on HS and can read the temp and activate/deactivate the relays, etc.
    When I try to send a command out a port, my emitters do not show any activity.
    I tested the emitters on a Xantech connecting block with a Xantech receiver and an IR remote and they work fine. It is a dual output emitter.
    I've tried all 4 ports on the BC4 and although everything acts like it should work, there is no flashing on the emitters.
    Running firmware 1.074
    Any ideas?
    -Tim
    HSPro - 3.XXX - Dell mini W7 x32
    Way2 Call
    Elk M1 Gold
    UPB HAI switches
    HAI RC2000 Thermostat
    Basics
    I expect you are using the BC4 interface below when you test the emitters?
    "When using the BC4 Plug-In, the HomeSeer "IR Signals" interface is not used. All IR codes and devices must be configured through the BC4 Plug-In's "IR Device Setup" interface."
    -just to eliminate the simple stuff -- hope that's all it is.
      Thanks for the feedback.
      I'm using the BC4's IR config. I wish it was that simple.
      I ended up removing the BC4 plug-in, reseting the BC4 with the reset switch, and starting all over. I have the same issue. No IR signals out of any ports.
      -Tim
      Way2 Call
      Elk M1 Gold
      UPB HAI switches
        Check your email, I sent you a procedure to try.
          That did it Mark.
          -Tim
          Way2 Call
          Elk M1 Gold
          UPB HAI switches
            What's the trick to fix - started happening to me now.
              Did you get help with this?
              -Tim
              Way2 Call
              Elk M1 Gold
              UPB HAI switches
                If someone could post the fix, that would make this thread a lot more useful!
                Learn About HomeSeer
                  I agree, but bitwise_Mark specifically mentioned not posting it.
                  I'll PM it to anyone who wants if Mark doesn't reply here.
                  -Tim
                  Way2 Call
                  Elk M1 Gold
                  UPB HAI switches
                    Jacy has been answered via email. The precedure used is not the same in all instances, and can cause problems if used inappropriately, which is why I have not posted anything publicly. If anyone has a similar issue, they can feel free to PM or email me.
                      I would like it
                      please
