Folks - Recently, I've been having troubles consistently controlling my AV system and when I look at the log I am getting a lot of BC4 connection problems. I re-installed the plugin but it didn't help. I'm running HS2 Professional Edition 2.5.0.80 (Service). Any ideas?
Here's the log:
5/12/2015 12:06:38 PM BC4 Plugin wsks error An existing connection was forcibly closed by the remote host
5/12/2015 12:06:38 PM BC4 Plugin 10.10.10.71 disconnected
5/12/2015 12:06:31 PM BC4 Plugin Initializing BC4
5/12/2015 12:06:31 PM BC4 Plugin BC4 Plugin connected to BC4 at 10.10.10.71
5/12/2015 12:06:28 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:06:22 PM BC4 Plugin wsks error An existing connection was forcibly closed by the remote host
5/12/2015 12:06:22 PM BC4 Plugin 10.10.10.71 disconnected
5/12/2015 12:06:20 PM Z-Wave Z-Wave WakeUp 'No More Info' Notification sent to Node 38
5/12/2015 12:06:19 PM Device Update Device: Main Floor Garage Garage Luminance value set to 2 (200/%)
5/12/2015 12:06:17 PM BC4 Plugin Initializing BC4
5/12/2015 12:06:17 PM BC4 Plugin BC4 Plugin connected to BC4 at 10.10.10.71
5/12/2015 12:06:08 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:05:58 PM BC4 Plugin wsks error An existing connection was forcibly closed by the remote host
5/12/2015 12:05:58 PM BC4 Plugin 10.10.10.71 disconnected
5/12/2015 12:05:55 PM Z-Wave Z-Wave WakeUp 'No More Info' Notification sent to Node 42
5/12/2015 12:05:55 PM Device Update Device: Outdoors Outdoors Lawn EAST Moisture Sensor Grid - Analog Lum Input value set to 47 (4700/%)
5/12/2015 12:05:52 PM Z-Wave Z-Wave WakeUp 'No More Info' Notification sent to Node 54
5/12/2015 12:05:52 PM Device Update Device: Outdoors Outdoors Everspring Humidity Outdoors value set to 48 (4800/%)
5/12/2015 12:05:51 PM BC4 Plugin Initializing BC4
5/12/2015 12:05:51 PM BC4 Plugin BC4 Plugin connected to BC4 at 10.10.10.71
5/12/2015 12:05:50 PM Device Update Device: Outdoors Outdoors Everspring Temp Outdoors value set to 16.6 (1660/C)
5/12/2015 12:05:48 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:05:28 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:05:08 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:04:51 PM Device Update Device: Outdoors Outdoors Garage - Aeon Outdoor Multi Sensor - Motion Status set to OFF/CLOSED/NO MOTION
5/12/2015 12:04:48 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:04:48 PM BC4 Plugin 10.10.10.71 disconnected
5/12/2015 12:04:40 PM Device Update Device: Top Floor Master Bedroom Ensuite Status set to DIM 69%
5/12/2015 12:04:28 PM BC4 Plugin Initializing BC4
5/12/2015 12:04:28 PM BC4 Plugin BC4 Plugin connected to BC4 at 10.10.10.71
5/12/2015 12:04:28 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:04:18 PM BC4 Plugin wsks error An existing connection was forcibly closed by the remote host
5/12/2015 12:04:18 PM BC4 Plugin 10.10.10.71 disconnected
5/12/2015 12:04:11 PM BC4 Plugin Initializing BC4
5/12/2015 12:04:11 PM BC4 Plugin BC4 Plugin connected to BC4 at 10.10.10.71
5/12/2015 12:04:08 PM BC4 Plugin Attempting to connect to BC4 at 10.10.10.71
5/12/2015 12:03:58 PM BC4 Plugin wsks error An existing connection was forcibly closed by the remote host
5/12/2015 12:03:58 PM BC4 Plugin 10.10.10.71 disconnected
Thanks!
Here's the log:
Thanks!
