I have updated to a newer computer
Just about everything is working ok. When I click the config on the bluetooth connector I am getting a error: I also am getting on other setup also, even using the updater. But they all are differant, this is the one for bluetooth, the program I use the most:
Server Error in '/' Application. <HR color=silver SIZE=1 width="100%">
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<TABLE width="100%" bgColor=#ffffcc><TBODY><TR><TD><CODE>
<!-- Web.Config Configuration File --><configuration> <system.web> <customErrors mode="Off"/> </system.web></configuration></PRE></CODE></TD></TR></TBODY></TABLE>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<!-- Web.Config Configuration File --><configuration> <system.web> <customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/> </system.web></configuration></PRE></CODE></TD></TR></TBODY></TABLE>
</P>
Runtime Error
</P>
