Here are two new versions of the Bluetooth Connector plugin:
- Version 0.30.2.1 is for HomeSeer 2.1. It's a native .Net 2.0 plugin.
- Version 0.30.2.0 is for HomeSeer 2.0. It's a native .Net 1.1 plugin
Change Log:
- Changed one help message in the Web configuration interface.
- Fixed a bug with UP / DOWN buttons in the Web configuration interface.
- Compiled new version 0.30.2.1 with .Net 2.0
- Tested with HS 2.1.8
To install or upgrade:
1) Download the right attached .ZIP (0.30.2.1 for HS2.1, 0.30.2.0 for HS2.0)
2) Unzip the archive without flattening the file tree (there are subdirectories that must be kept)
3) Shutdown HomeSeer
4) If you are upgrading, DELETE the HomeSeer 2/html/hspi_bt directory
5) Copy all unziped files and subdirectories to your HomeSeer 2 directory
6) Restart HomeSeer
7) Enjoy
[EDIT] Attachment for HS2.1 removed, as a new version is available from the Forum. Attachment for HS2.0 kept, as it's the last version compatible with HS2.0
Change Log:
6) Restart HomeSeer
7) Enjoy
