Bluetooth Connector 0.30 (for HS 2.1 and HS 2.0)
Service Discovery might be very slow for your device.
You should try to increase the polling period, so that the plugin doesn't try to rediscover the services if the previous service discovery has not finished yet.
I'll add a fix in the next version, and test if ServiceDiscovery is already running before running a new ServiceDiscovery on the same device.
I have it working for 10- 30 minutes then all devices is lost.
When I get the "A service discovery is already pending" in the debuglog all device is lost until I restart the computer.
2006-04-27 20:49:25 BT Debug Polling .P900 (Method=DiscoverService) on Network0
2006-04-27 20:49:25 BT Debug Service discovery started for device .P900
2006-04-27 20:49:25 BT Debug Error while polling .P900: A service discovery is already pending
2006-04-27 20:49:25 BT Debug Polling .P900 (Method=DiscoverService) on Network0 returned signal strength=-2147483648
Where do I change Service Number?
However, if it makes a strong connect sound with default service 1, it will be the same with other services...
I don't understand why the plugin cannot discover the BT services on your phone. I couldn't find any BT device here with a similar problem.
Hi
If I use ConnectService all the phones are getting av message from the homeseer computer and have to put a secret code. I did this on one phone and every time the BT connector poll, the phone make a strong connect sound.
You can try with Service Numbers 1,2, 3 ... etc.
Thanks...
Bluetooth must be active on your phone, that's all. Maybe the services are not discoverable on your phone ?
Can you try with the ConnectService poll method ?
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>Hi Stipus
2006-04-24 23:12:05
</TD><TD class=LOGType0 align=left colSpan=3>BT Debug </TD><TD class=LOGEntry0 align=left colSpan=8>Error while polling Angelica: Failed to find services on the device due to a connection error</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>2006-04-24 23:12:05 </TD><TD class=LOGType1 align=left colSpan=3>BT Debug </TD><TD class=LOGEntry1 align=left colSpan=8>Polling Angelica (Method=DiscoverService) on Network0 returned signal strength=-2147483648</TD></TR></TBODY></TABLE>
I change to DiscoverService, but getting errors. Do I need to anything on the phone?
Hi there,
The signal strenght doesn't work with the Autodiscovery poll method.
To access signal strength, the plugin must physically (over the air) connect to the Bluetooth device, and this requires the "ConnectService" or the "DiscoverService" poll method.
Regards,
stipus
Yes I start over and install a fresh windows xp, a new install of HS 2.0 /2.1 and the drivers for the BT device. So now is it running perfect with widcomm.
You did reinstall the OS ?
Now does the BT plugin work as expected ?
I reinstall my xp-machine, that solved many problems with the bluetooth and sip plugin.
/Tony
I bought my third usb bluetooth device, the Linksys BT100 that I whas recommended in the early in the threads. http://board.homeseer.com/showthread...sys#post702719
I start thinking that I doing something wrong. Have removed BlueToolsMS.dll from hs2 directory.
Initializing interface: BT Connector->Error: bluetooth manager can't be found
PS.
Thanks for all support and great plugin.
In the next version of the plugin, I will add a way to force which stack the plugin use, in case both MS and Widcomm stacks are installed.
