Using the Plug-in simultaneously with a Bluetooth Headset
This topic is closed.
    Stipus,
    I downloaded your plug-in last friday. I have HS2.0-2041. I was checking the with the DiscoverService Pool Method for Nokia and BlackBerry 7100g phones.
    However, if I connect my Plantronics BlueTooth Headset Explorer 320 to my BlackBerry, the plug-in doesn't detect anymore my phone and the status of the device change to "Device Away" (following the same samples you write in the documentation).
    Is it normal?... Do you recommend another kind of Pool Method?... I don't want to use AutoDiscovery because it is mandatory to have the bluetooth connection on the phone visible to everyones.
    Thanks in Advance,
    Some BT device can only handle one connection, and some device can't reply a Discover service packet when they are busy on another connection...
    You can try the ConnectService poll method, maybe with a Poll Service Number=2 or 3.
    stipus
