Here is a new version of the Bluetooth Connector plugin for HomeSeer 2.2 beta:
As you may know, ASPX processing has changed a lot with HomeSeer 2.2 beta, and the Configuration pages could not be loaded anymore.
Change Log:
- Upgraded the Bluetooth support Library to V1.20 (was V1.10 in all the previous versions)
- Reworked the ASPX config pages to support HS2.2 beta
- Changed the way the configuration interface displays HomeSeer page header and footer.
- Added a warning to the HS Event Log in case of missing hardware (BT key)
- Added some help message in the Web configuration interface.
- Fixed a nasty bug occuring when the plugin is ran on a Windows domain Controller.
- Fixed a bug preventing the web configuration interface to load when the Instant Messenging Connector was installed.
- Added the Serializable() attribute to the plugin class.
- Tested with HS 2.1.102 and HS 2.1.130
To install or upgrade:
1) Download the attached .ZIP
2) Unzip the archive without flattening the file tree (there are subdirectories that must be kept)
3) Shutdown HomeSeer
4) If you are upgrading, DELETE the HomeSeer 2/html/hspi_bt directory
5) Copy all unziped files and subdirectories to your HomeSeer 2 directory.
If you are upgrading you have to accept replacing the bluetooth support dlls, as all these files are new versions.
6) Restart HomeSeer
<!-- / message --><!-- attachments -->
Change Log:
6) Restart HomeSeer
