I sent just sent a new version 0.42.2.2 to the updater.
The delete bug is fixed.
A (non-fatal) error that could sometimes appear when autodiscovery interval was set too fast (faster than the dongle could handle) is fixed. I now check for any pending device discovery before running a new discovery.
Best regards,
stipus
Bug Fix ??
I get the same HS error now and again...I am not sure why...it tends to happen when the HS server hasn't got access to the internet...well it does for me at least!
MAybe... when i registered your stuff, i lost all my licenses and had to re-enter
Have a lot going on, so not sure on timing ...but may be interesting bug
THANKS for the, again, quick reply
I shall take the easy road and wait !!
btw.... Hmmmmm.
fyi
g
I fixed the bug, but didn't publish the new version yet. I'll do this soon.
In the meantime, you can shutdown HS, edit Config/hspi_bt.ini, and remove all [device x] sections.
If you don't want to remove them all, you must renumber them 0, 1, 2, 3...
Bug Fix ??
Have you fixed the bug preventing DELETE ??
Now that I am smarter, I need to erase junk and re-doTags: None
