Stack Problem
    Stack Problem
    Hi guy's, brand new to this plugin so a little help please. I have an error in the log
    BT Connector Scanner Error: Bluetooth is disabled. The MS Bluetooth stack cannot be found (first device).
    I have no clue where to start.
    thanks
    Mike
    Can you tell us a little more about your system ?
    What operating system ?
    What version of HomeSeer ?
    Which Bluetooth dongle ?
    Which Bluetooth stack ?
    stipus
      Hi Stipus,
      What operating system - Win XP Pro
      What version of HomeSeer HS 2.2
      Which Bluetooth dongle - Ambicom model BT2000C-USB
      Which Bluetooth stack - MS
        That's weird because the manual I found for this dongle says it comes with the Widcomm stack.
        Are you certain you didn't install a specific Bluetooth stack, and that you are using the Windows XP SP2 Bluetooth stack ?
        stipus
          Yes I believe i did use the MS stack and only found out that it should be the widcomm afterwards. I tried to reinstall but I do not know where to look to change the stack setting.
          Mike
