I installed the Bluetooth Plugin v0.40.2.2. The plugin initializes fine but it does not see my bluetooth phone when I scan for device. The computer sees the device but homeseer does not. I am using Linksys USBBT100 USB adapter. Any help?
Need Help -Bluetooth Connector - No Client Found?
Then I don't really understand what could be the problem...
Are you sure Bluetooth detection is turned on on your device ?
Can you post the first few plugin log lines from HS event log ?
Can you try turning DEBUG mode on from the plugin web configuration interface, and then see if there is any error message when you hit the scan button.
stipus--
stipus
