No Client found error.
    I'm having some problems getting my bluetooth to work. I am moving my config to a new machine. I get this error when starting the BT plugin.
    6/28/2007 12:00:47 PM - BT Connector - Network0: Remote Bluetooth Network Enabled= True AutoDiscovery=True AutoDiscoveryInterval=5 No client found
    Using the normal bluetooth app provided by Linksys everthing works fine. I can browse and connect to my phone.
    Any ideas?
    Did you move the hspi_bt.ini file from one computer to another ?
    The Bluetooth Network is identified with the computer SID in the INI file. Try to remove the [Network0] section and restart HS.
    stipus
      That did the trick. Many thanks!
