Detection of my other phone (Motorola Q) worked fine last time I tested this, but suddenly stopped. I try a scan for new devices (for the heck of it to test the system) and I get the error below. Last time I had that error, I tested the Microsoft scan, and saw that it had problems, but this time Microsoft can find the device, no problem.
Any ideas?
Server Error in '/' Application.
Bluetooth is disabled. The MS Bluetooth stack cannot be found (first device).
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Exception: Bluetooth is disabled. The MS Bluetooth stack cannot be found (first device).
Source Error:
An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.
Stack Trace:
[Exception: Bluetooth is disabled. The MS Bluetooth stack cannot be found (first device).]
System.Runtime.Remoting.Proxies.RealProxy.HandleReturnMessag e(IMessage reqMsg, IMessage retMsg) +1734594
System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) +826
HSPI_BT.BtScanner.ScanForNewDevices() +0
hspi_bt_web.DeviceList.scanButton_Click(Object sender, EventArgs e) +24
System.Web.UI.WebControls.Button.OnClick(EventArgs e) +75
System.Web.UI.WebControls.Button.RaisePostBackEvent(String eventArgument) +97
System.Web.UI.WebControls.Button.System.Web.UI.IPostBackEven tHandler.RaisePostBackEvent(String eventArgument) +7
System.Web.UI.Page.RaisePostBackEvent(IPostBackEventHandler sourceControl, String eventArgument) +11
System.Web.UI.Page.RaisePostBackEvent(NameValueCollection postData) +33
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +4921
Version Information: Microsoft .NET Framework Version:2.0.50727.832; ASP.NET Version:2.0.50727.832
Any ideas?
Source Error:
Stack Trace:
