Bluetooth client crashes...
    I figured I'll try this plugin and allthough it is not perfect (I blame my bluetooth dongle for that), it works.
    However, I figured I would install the client on my work computer. It has the same dongle as the server has at home (both running WinXP). But it only crashes when it connects!
    I have the Script Client running on the same machine without problems...
    Any pointers?
    EDIT: Some info.
    This is the error:
    System.Reflection.TargetInvocationException: Exception has been thrown by the target of an invocation. ---> System.IO.FileNotFoundException: Could not load file or assembly 'BluetoothClient, Version=2.45.2.2, Culture=neutral, PublicKeyToken=null' or one of its dependencies. The system cannot find the file specified.
    File name: 'BluetoothClient, Version=2.45.2.2, Culture=neutral, PublicKeyToken=null'
    Apparently I'm using this version of the MS stack:
    11:02:39 Microsoft Bluetooth Stack 5.1.0.2600
    If I click "Continue" on the .NET error dialog, it seems like the client connects every 5 seconds...
    Update:
    I've tried adding the .exe file til the HomeSeer 2 directory on the server, and adding SKCLNET.dll in the directory of the client. No change..
      You need to add BluetoothClient.exe to the HomeSeer 2 directory on the HomeSeer server.
      This fixed the problem for other users.
      stipus
        Like I said, I've already tried that...
        (But I didn't restart HS as it seemed unessecary).
          I realise it's vacation time, but a little hint would be great...
            Honestly I have no clue. If you did copy BluetoothClient.exe to the server HomeSeer 2 directory, and restarted everything, it should have worked.
            I'll be back from vacation on the 15th of August, and I have no access to my computers to try / test / fix anything before then.
            stipus
              No worries, I'll wait.
              I just upgraded my server, so now I need a bluetooth dongle that has Windows 2003 server drivers...
