Local BT Adaptor no longer seen as local
    I have just come to complete a new local scan to add some new devices into the system and I have just noticed that the local dongle is not being reported as local (no tick in the box). How do I force the HS install to connect network 0 back to the local dongle.
    Is there a ini setting I can inject to correct this?
    Darren
    You could try to make a backup of the .ini file, then clear the [Network0] section from the ini file and retsart HomeSeer.
    Local/Remote is based on computer SID. Did you change your computer SID ? This may happen if you add your computer to a domain or using Ghost tools to restore the system...
    stipus
      That's cured it thanks
