auto-discovery is an asynchronious process. You can't set the frequency for it. The bluetooth stack auto-discovers the device when the device sends a hello message.
You can poll every minute in auto-discovery mode to check every minute if your phone is here.
Set the "Lot Confirm" parameter to 2, to check 2 more times when the device is not seen, before changing the Homeseer device status back to "lost"
Confusion
thanks stipus,
Let me try and ask my question a little more clearly- just remember I don't fully understand what is happing, so I may be missing something that is to you blindingly obvious.
in my log I see
26/07/2010 1:11:05 PM BT Debug AutoDiscovery found 5 device(s)
26/07/2010 1:11:30 PM BT Debug Polling SGH-i900 (Method=AutoDiscovery) on Network0 returned signal strength=0
26/07/2010 1:11:55 PM BT Debug AutoDiscovery found 6 device(s)
26/07/2010 1:12:30 PM BT Debug Polling SGH-i900 (Method=AutoDiscovery) on Network0 returned signal strength=0
26/07/2010 1:13:01 PM BT Debug AutoDiscovery found 6 device(s)
I am trying to find out exactly what the relationship between polling and autodiscovery is.
If I am on AutoDiscovery do I even need polling?
If the staus does not change back untill the next AutoDiscovery happens- what is the point of polling?
Is it possible to set the frequency of the AutoDiscovery?
Or perhaps the most important question-
Lets say I want to use AutoDiscovery, I want it to check every minute to see if my phone is there, if it is not, I want it to try two more times (also a minute apart), before changeing status- what should my setings be.
Originally posted by brenton.prettejohn View PostHi
Just wondering if I could get some information- I am using AutoDiscovery. When I check the log I can see the status that is returned from a 'poll' does not change unless a 'discovery' has happened. I have done some testing, and there can be several polls after my phone is switched of, but the status does not change to -whatever until the AutoDiscovery, at which point the next poll has the new result. My reason for asking is I am trying to work out best timing and wanted to know what the relationship between the two was?
Yes triangulation only works with the Widcomm stack. But do not place too much hope on bluetooth triangulation. This is really approximate, and a bit difficult to configure. I stopped using it myself.
This one is probably even more obvious but just in case- the 'clients' have to be one of the two supported stacks?<O</O
Confusion
Hi
<O</O
Tags: None
