Config check and script question
    Hi,
    I'm new to using the plug-in and so far all is working well.
    Here's my config:
    Rocketfish RF-FLBTAD adaptor with latest widcomm stack on XP SP2
    iPhone 4 pair with PC
    Using DiscoverService method
    Is pairing the device and using DiscoverService the best known method for iPhones?
    Also, how do I add the BT Connector DLL to Scripting References so I can use the following command to reload the plug-in after changing the poll interval?
    hs.plugin( "BT Connector").scanner.Devices( "Device0" ).ReloadConfig()
    Thanks!
    -Mike
    Originally posted by msbreton View Post
    Hi,
    Here's my config:
    I'm not sure if it's the best method for an iPhone. If it works for you, then I think it's fine. Did you double-check if the plugin stops finding your iPhone when you are away ? Sometimes, with some BT stacks, the phone is always found when paired... (even if it's off !)
    You have to add the following at the top of your VB.NET script:
    PHP Code:
    Imports HSPI_BT
    You also have to add the DLL as a scripting reference in the file Config/settings.ini
    Find the line ScriptingReferences=
    Add the following at the end of the line (change the exact dll path as needed)
    PHP Code:
    ,HSPI_BT;C:\Program Files\HomeSeer 2\hspi_bt.dll
    Restart HomeSeer.
    stipus
      Thanks. Yes, it's working fine with the iPhone paired and using DiscoverServices. When out the range, it switches to Away. I was just asking if this was the best method. Sounds like it is. Thanks for the info.
      One more question: Is there a way to see the last reported signal without drilling down in to the plug-in config settings? I thought I saw in some release notes that the plug-in included the last known signal level in to the device somehow but I'm not seeing it.
      Thanks!
      -Mike
        You have to go to the plugin configuration to see the signal strength reported by the BT stack.
        stipus
