Hi!
I just installed BT connector on a trial basis. On the configuration page of the BT device list, i press the "Scan new bluetooth devices" button and after a few seconds, I get the following error: server application error "/". See the attached image (text is french). I assume the plugin itself is working properly because I put it in debugging mode and I can see "2012-06-03 16:53:11 - BT Debug - AutoDiscovery found 0 device(s)" every minute or so.
I'm running Windows 7, my BT 2.0 device is listed as "microsoft Bluetooth".
Any idea?
Thank you!
Any idea?
Thank you!
