So, when I first got HomeSeer I used the trial of this plug-in, but never got it to work. Every time I would go to scan a device I would get a "Server Error in '/' Application" errror.
Today, however, I decided I wanted to retry the plug-in with the newest version of HomeSeer. So, I bought the plug-in since the trial was up, and tried it again, but I got the same "Server Error in '/' Application".
Well, I disabled the plug-in and tried to see if there was an update in the updater, but now when I go to the updater I get the "Server Error in '/' Application" error with the following errors:
Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the <configuration>\<system.web>\<httpModules> section in the application configuration.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.Web.HttpException: Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the <configuration>\<system.web>\<httpModules> section in the application configuration.
Source Error:
<table bgcolor="#ffffcc" width="100%"> <tbody><tr> <td> <code> An unhandled exception was generated during the execution of the current web request. Information regarding the origin and location of the exception can be identified using the exception stack trace below.</code> </td> </tr> </tbody></table>
Stack Trace:
[HttpException (0x80004005): Session state can only be used when enableSessionState is set to true, either in a configuration file or in the Page directive. Please also make sure that System.Web.SessionStateModule or a custom session state module is included in the <configuration>\<system.web>\<httpModules> section in the application configuration.] System.Web.UI.Page.get_Session() +146 _WebForm1.Page_Load(Object sender, EventArgs e) +622 System.Web.UI.Control.OnLoad(EventArgs e) +73 System.Web.UI.Control.LoadRecursive() +52 System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +2184 </pre></code></td></tr></tbody></table>
Source Error:
Stack Trace:
