I finally got my RFID receiver installed this weekend and setup two of my four tags in preparation for doing some testing. At the moment I have a 40M and a 8M setup. Everything appeared to work great for about 8 hours or so and then all of a sudden the two tags changed to away without ever leaving the house. They both changed two 'Away' within a second of each other. After leaving the system alone for an additional day to see if the tags would come back (they didn't), I finally went into Homeseer and disabled the plug-in and attached to the receiver via hyperterminal; the tags were still reporting in to the receiver as they should. I then disconnected from hyperterminal and re-enabled the plug-in. Still, the tags were reporting 'away'. I then completely shut down HomeSeer and restarted it. After doing this the tags came back. This has happened two times thus far. Each time the tags go 'away' at the same time and a restart of HomeSeer (thus the plug-in) is required to recover.
My receiver is installed in my old sprinkler timer case mounted on my garage wall and the 1 40M tag is in the glove box of one of my cars approximately 4 meters from receiver when the car is parked in the garage. The 8M tag is in my Wife's purse in the house.
I am trying to determine if this is a receiver saturation issue (I.e. the 40M overloading the receiver when the car is in the garage) or a plug-in issue.
Has anyone else experienced this issue?
I'm excited about getting my tags setup and getting some events created to take advantage of this cool new addition to my home automation, however it is unusable in its current state.
If anyone has insight on this issue I would love for them to share their thoughts.
