Hello all,
I'm having a lot of problems with dropouts on my 8m and 40m tags, and always have had problems. I added a second receiver inside the house, which helped a bit, and have been tweaking the discrimination, which helped a bit.
I'm starting to work on fixing some of the core infrastructure problems in my home automation system, and the RFID tags are on the list.
I think part of the problem is either with the closeness of the 40m RFID tags (they're within 20ft of both receivers) or the fact that the house is clad in aluminum siding, or both.
One option is for me to move one of the receivers out to the barn, where I have a serial-to-ethernet router. That'd be fine for the 40m tags, where I just need to know if they're in range or not. The problem is, I need to be able to determine the relative proximity of the 8m tag, which is in the dog's collar.
If I can figure out whether the 8m tag is being received inside the house, or being received inside the barn, I can figure out where the dog is. I'd even be willing to have separate devices for inside vs outside, to the point where I'd even be willing to deal with hacking the plug-in to support what I'm trying to do -- the 8m tag has a fixed name, so mangle the name slightly when it comes in on the second receiver, such that it looks like it's a different device.
Anyone have any comments?
Chris
Chris
