DirecTV Plug-In
This is a sticky topic.
  • lpitman
    The only officially supported Receivers are listed on post #1.
  • kirving1
    Any word on HR 24 support?
  • afmiller
    Just checking to see if you have any update on the HR 24. I would love to have this plug in
  • johnoc
    Larry, thanks for the beta. I thought I'd share my results... My HR23 does connect and the on/off"power" device does toggle the STB on and off. The status of the HS devices is not accurate, even the Power device which does work when controlling the power, is not reflecting any change (i.e. just show off). Since my STB is not in the drop down on the config page, I'm not sure what impact that may have on the fuctionality. Let me know if you'd like me to test anything or if I can help in anyway...
    -John
  • lpitman
    John...this is still pretty rough...but give it a try...remember it is BETA.
  • johnoc
    Larry,
    Just checking in on the progress of the IP connectivity. I just got a new HR23-700 and would love to get the plug-in working with it. I know the eithernet port is there, but not sure if it has a USB or serial (I'm not at home now). Do you happen to know if others have gotten to work with this box?
    -John
  • lpitman
    Strange, because the Log does not look complete...I will investigate why it is not being logged. The log should be giving me clues from every routine contained in the plug-in, to aid in troubleshooting issues.
  • Mark S.
    Originally posted by lpitman View Post
    you posted a clip from the HS log not the file in the log directory NAMED DirecTV.log
    No, it is the DirecTV log. Nevertheless, I have attached the whole file here.
    Again, the dtvcon program works fine on the same COM port, but the HS plugin does nothing.
    The only error I see in the HS log is when I try to change the channel:
    DirecTV Error~!~Exception error in PagePut()-->For-Next Loop.
  • Dafunktyfunk
    Looking at new API...but it looks more like web based calls to on board web server...still need to investigate further...my knowledge of JAVA and ASP are limited.
    Excellent! Please keep up the great work!
  • lpitman
    Originally posted by Dafunktyfunk View Post
    Hey Larry, just checking in to see how it oes with the ip control of the new h24 is going?
  • lpitman
    Originally posted by Mark S. View Post
    I thought I did that in the post above.
  • Dafunktyfunk
  • Mark S.
    I need the DirecTV.log file...it is in the log directory and is verbose straight from the plug-in.
    If you can attach that here, I can use it to diagnose your issue.
  • lpitman
  • Mark S.
    I'm still having problems getting the plugin to work. I followed the innstructions above.
    The dtvcon.exe works on COM3, but the plugin does nothing on the same port.
    Any more sugestions?
    A snippet of the debug log is below:
    1/16/2011 5:20:40 PM~Entering ShutdownIO()...
    1/16/2011 5:20:40 PM~Entering CloseComPort()....
    1/16/2011 5:20:40 PM~Entering RegisterCallback()...
    1/16/2011 5:20:40 PM~Entering InitIO()....
    1/16/2011 5:20:40 PM~WriteDebugLog()- Log directory already exists.
    1/16/2011 5:20:40 PM~About to read config file entries
    1/16/2011 5:20:40 PM~Entering LoadConfigSettings()....
    1/16/2011 5:20:40 PM~***************************************
    1/16/2011 5:20:40 PM~DirecTV Debug Enabled.
    1/16/2011 5:20:40 PM~DirecTV Debug Logging to AppDirPath\Logs\DirecTV.log.
    1/16/2011 5:20:40 PM~DirecTV HS-Version: 2.4.0.11
    1/16/2011 5:20:40 PM~DirecTV Plug-In Version: 2.2.0.12
    1/16/2011 5:20:40 PM~Entering InitHW()....
    1/16/2011 5:20:40 PM~Entering...InitDevices().
    1/16/2011 5:20:40 PM~Entering...EnumerateDevices().
    1/16/2011 5:20:40 PM~Found a plug-in device at (1
    1/16/2011 5:20:40 PM~Entering...CreateDevices().
    1/16/2011 5:20:40 PM~Entering InitCommon()....
    1/16/2011 5:20:40 PM~Entering InitDirecTV()....
    1/16/2011 5:20:40 PM~Entering ComPort()....
    1/16/2011 5:20:40 PM~InitIO()->Initialized DirecTV Plugin successfully
    1/16/2011 5:20:51 PM~GenPage called with: /directv_control
    1/16/2011 5:20:57 PM~Entering...PagePut()
    1/16/2011 5:20:57 PM~GenPage called with: /directv_control
    1/16/2011 5:21:00 PM~Entering...PagePut()
    1/16/2011 5:21:00 PM~GenPage called with: /directv_control
    1/16/2011 5:21:03 PM~Entering...PagePut()
    1/16/2011 5:21:03 PM~GenPage called with: /directv_control
    1/16/2011 5:23:11 PM~clsWebLink1--->GenPage() called with: /directv_config
    1/16/2011 5:24:05 PM~Entering ShutdownIO()...
    1/16/2011 5:24:05 PM~Entering CloseComPort()....
    1/16/2011 5:26:11 PM~***************************************
    1/16/2011 5:26:11 PM~DirecTV Debug Enabled.
    1/16/2011 5:26:11 PM~DirecTV Debug Logging to AppDirPath\Logs\DirecTV.log.
    1/16/2011 5:26:11 PM~DirecTV HS-Version: 2.4.0.11
    1/16/2011 5:26:11 PM~DirecTV Plug-In Version: 2.2.0.12
    1/16/2011 5:26:11 PM~Entering InitHW()....
    1/16/2011 5:26:11 PM~Entering...InitDevices().
    1/16/2011 5:26:11 PM~Entering...EnumerateDevices().
    1/16/2011 5:26:11 PM~Found a plug-in device at (1
    1/16/2011 5:26:11 PM~Entering...CreateDevices().
    1/16/2011 5:26:11 PM~Entering InitCommon()....
    1/16/2011 5:26:11 PM~Entering InitDirecTV()....
    1/16/2011 5:26:11 PM~Entering ComPort()....
    1/16/2011 5:26:11 PM~InitIO()->Initialized DirecTV Plugin successfully
    1/16/2011 5:26:58 PM~GenPage called with: /directv_control
    1/16/2011 5:27:05 PM~Entering...PagePut()
    1/16/2011 5:27:05 PM~GenPage called with: /directv_control
    1/16/2011 5:27:11 PM~Entering...PagePut()
    1/16/2011 5:27:11 PM~GenPage called with: /directv_control
    1/16/2011 5:27:25 PM~Entering...PagePut()
    1/16/2011 5:27:25 PM~GenPage called with: /directv_control
    1/16/2011 5:27:27 PM~Entering...PagePut()
    1/16/2011 5:27:27 PM~GenPage called with: /directv_control
    1/16/2011 5:27:38 PM~Entering...PagePut()
    1/16/2011 5:27:38 PM~GenPage called with: /directv_control
    1/16/2011 5:27:46 PM~Entering...PagePut()
    1/16/2011 5:27:46 PM~GenPage called with: /directv_control
    1/16/2011 5:27:54 PM~GenPage called with: /directv_control
