Using IP to talk with DirecTV
New DirecTV plugin
the new DirecTV plugin for HS3 is ready: http://board.homeseer.com/forumdisplay.php?f=1152
Sounds like you may have to run with this one as I think we are on our own.
How is the status of this one coming? I would love to help you if your still having issues. Otherwise I am gonna have to write my own plugin... and I rather not start from scratch
Larry, Just checking in to see if you've had any luck with the plug-in talking over IP? I haven't had much time lately to mess with my setup, but hope to this weekend. I may just go ahead and order the USB to Serial device and use that (I believe my HR23-700 has a USB port?). Do you know if the serial protocol works on the HR23?
Thanks...
John
How's the alpha coming and any idea on when a beat will be done? I would rather get your ip plugin verses programming an GC-IP2IR.
Originally posted by johnoc View PostLarry, how goes the IP work? I'm finially ready to automate my HR23-700 so I'm looking forward to the update.
-John
-John
FYI.
I just I would post that I am making some progress on an IP version of plug-in. So far I have commands working being sent to STB, but responses need some work.
Don't know for sure, but try it...you can evaluate plug-in before buying.
IP is still being investigated...but API and examples are JAVA and Web based which is not my strong point. I am fairly good at VB (most of the time). But we will see how it progresses.
I just upgraded to HD with Directv. My receiver is an HR24-100 and is on my internal network. Will this plug-in talk to this model receiver?
Originally posted by lpitman View PostI found a DirecTV Public Beta IP Command Set Document, for using IP to send commands to STV boxes that are equipped with an ethernet port. Hopefully I can gleen enough info to add some IP capabilities to the plug-in.
Not a promise, but I will investigate.
Thanks for working on this!
Not a promise, but I will investigate.Tags: None
