The following Requests have been received:
Open:
Create HSELK: command set - Requested by FryGuy
Status - 2 (Medium Priority)
Download tasks into events
Status - 3 (Low Priority)
Allow access to Counters
Allow access to custom values
Ring Chime upon event
Change labeling of keypad temperature
Closed:
Allow ability to disarm panel
Status - Added as event trigger.
Allow disconnect from panel for testing
Status - Added in version 2.3 (As of 8/18/06 still in testing)
Trigger Events based on panel alarm
Status - 2 (Medium Priority) - Added in 2.2.47
Activate an event from a keyfob button
Status - Investigation - Unsure if this is possible
Cannot locate an ASCII command that will allow this. Users should
develop a workaround (i.e. virtual x10 device triggered from Elk)
Add Trigger for panel disconnect
Status - Done v2.2.0.24 - 7/26/2006 - To be posted soon.
Add capability to add one device at a time rather than recreate all. Investigate auto device creation
Status - Done -v2.2
Add voltage measure to zone capabilities
Status - Done - v2.2
Add support for multiple thermostats
Status - 2 (Medium Priority) - Added to 2.0.155
Add No Logging option to suppress logging of zone changes
Status - 2 (Medium Priority) - added to 2.0
Exit delay functionality is compromised by duplicate messages from the M1. See if there is a workaround.
Status - 1 Closed - fixed in version 2.0
Communicate last arm/disarm with plug-in for trigger
Status - Closed - Implemented in Elk-M1 2.0 (Beta)
Add Arm Night and Arm Vacation to the actions tab
Add support for Lutron RadioRA RS-232 interface
Status - 1 (High Priority) - addressed in version 1.7
Increment temp by +/- X degrees
Closed - addressed in version 1.6.5
Implement current alarm state of partitions
Status - Closed - Panel does not send entry/exit delay information without polling.
Ability to examine ELK log from HS web pages
Status - Closed - Available via web page
X-10 Enhancement
Status - Closed
Comments - Complete
Add Output control
Status - Complete (v1.5)
Add Custom value control
Status - scripting interface added to version 1.5
Zone and area name to HS device population
Status - added to v1.5
Preparation for the Ethernet interface (due in a couple of weeks)!!!
Status - complete (v1.5)
Open:
Closed:
Status - Done -v2.2
X-10 Enhancement
Status - Closed
Comments - Complete
Add Output control
