I must be missing something, when I launch HS it keeps logging the M1's IP address, but never connects. I can use the ethernet interface to connect to the M1 to HS correct?
Mike
Mike
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
