I am installing my HS on a new computer. I decided to start from scratch and clean everything as I went. I installed the new ver. of HS and everything was working good. When I installed the Elk plug-in, my HS has quit working. I am getting the following errors:
<TABLE cellSpacing=2 cellPadding=0 width="100%" border=0><TBODY><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:11 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/22/2006 11:23:11 PM </TD><TD class=LOGType1 align=left colSpan=3>Warning </TD><TD class=LOGEntry1 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:11 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/22/2006 11:23:11 PM </TD><TD class=LOGType1 align=left colSpan=3>Warning </TD><TD class=LOGEntry1 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:11 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType1 align=left colSpan=3>Info </TD><TD class=LOGEntry1 align=left colSpan=8>Device: Kitchen Single Overhead Can Light (K3) ON</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType1 align=left colSpan=3>Warning </TD><TD class=LOGEntry1 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime1 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType1 align=left colSpan=3>Warning </TD><TD class=LOGEntry1 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR><TR><TD class=LOGDateTime0 noWrap align=left>7/22/2006 11:23:15 PM </TD><TD class=LOGType0 align=left colSpan=3>Warning </TD><TD class=LOGEntry0 align=left colSpan=8>In CommitDeviceStatusNow-Inner Loop at line 37 More: Index was outside the bounds of the array.</TD></TR></TBODY></TABLE>
When I tried to set up the conf. for the plug in, it will not let me change the com port setting. When I change it to ethernet and the ip address of 192.168.0.104, the Log in shows that HS is trying to connect on serial com port 192.
Any Ideas?
I have restarted HS several times and also restarted the pc.
steve
Any Ideas?
steve
