Emotion on HomeSeer v2.3.0.19
This topic is closed.
    Can someone help me?
    I have an error near the instalation on the computer that says (an unhandled exception has occurred in your application) I can do anything with that?
      file:///C:/WINDOWS/Microsoft.NET/Fra...9/mscorlib.dll
      Emotion
      Version de l'assembly : 1.7.0.0
      Version Win32 : 1.7.0.0
      CodeBase : file:///C:/Program%20Files/HomeSeer%20HS2/Emotion.exe
      Microsoft.VisualBasic
      Version de l'assembly : 10.0.0.0
      Version Win32 : 10.0.30319.1 built by: RTMRel
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...isualBasic.dll
      System
      Version de l'assembly : 4.0.0.0
      Version Win32 : 4.0.30319.236 built by: RTMGDR
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...089/System.dll
      System.Core
      Version Win32 : 4.0.30319.1 built by: RTMRel
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...ystem.Core.dll
      System.Windows.Forms
      Version Win32 : 4.0.30319.235 built by: RTMGDR
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...dows.Forms.dll
      System.Drawing
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...em.Drawing.dll
      System.Runtime.Remoting
      Version Win32 : 4.0.30319.1 (RTMRel.030319-0100)
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...e.Remoting.dll
      System.Configuration
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...figuration.dll
      System.Xml
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...System.Xml.dll
      Accessibility
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...essibility.dll
      mscorlib.resources
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass....resources.dll
      System.Speech
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...tem.Speech.dll
      HomeSeer2
      Version de l'assembly : 2.1.0.0
      Version Win32 : 2.2.0.67
      CodeBase : file:///C:/Program%20Files/HomeSeer%20HS2/HomeSeer2.DLL
      Scheduler
      Version Win32 : 2.3.0.19
      CodeBase : file:///C:/Program%20Files/HomeSeer%20HS2/Scheduler.DLL
      ilzothvw
      qftyzfcn
      zj4ireee
      System.Windows.Forms.resources
      HS2Util
      Version de l'assembly : 1.0.0.0
      CodeBase : file:///C:/Program%20Files/HomeSeer%20HS2/HS2Util.DLL
      System.Web
      Version Win32 : 4.0.30319.206 built by: RTMGDR
      CodeBase : file:///C:/WINDOWS/Microsoft.Net/ass...System.Web.dll
        Hi Loup,
        We cannot work out from the error what is going on. Please can you give us as much information as you can about what happened when the error occurred so that we can try and recreate this in our test lab.
        Sorry about that - we have not seen this one before
          So the error occurs when I want to colect a HomeSeer emotion, as soon as Emotion opens on the desktop there is the error mentioned above I must clik on continue or exit, continue does nothing and leaves out, can you help me?
            I said that you would need to know the problem well, Enjoy Your help would be ....
              Loup,
              What version of Homeseer are you using? Older versions do not support the hs.writelogex function which has been used.
              Jon
                I have version 2.3.0.19 professional edition
                  That looks like the issue then. You will either have to upgrade to the latest version of Homeseer or persuade emotion to recompile the plugin using hs.writelog rather than hs.writelogex command.
                  Jon
                    Okay, so it will never work
                    I do not want to change my version, it very well it's going, I still have version 2.3 which is not that old?
                    They make plug-in only for new versions?
                    Wish I could buy this plug-in me!
                    Enfain I am very disappointed in this situation, emotion was interresting for me
                    Thank you very much for your information, if others have had this problem in the past, I would like to be informed please
                    thank you
                      Hi Loup,
                      I'll take a look to see if there is a specific reason why we use the hs.WriteLogEx method. If there isn't or if it's minor we can do a version check workaround for this.
                        Originally posted by Emotion View Post
                        Hi Loup,
                        Wow, that would be wonderful, you gives me hope that this to can be walking one day,
                        I wait from you on this subject,
                        hank you again
                          I can be the new
                          I downloaded on another computer HomeSeer brand new (Version trials day) I went and I instaler download Emotion in HomeSeer settle into it's ok, I Started Emotion, the same error, bizare right? This computer is with w7 and not with xp and I have the same error?? I do not understand anything, two different computers and same error,,, When do you think?
                            I still have this same error every boot, that what one knows?
                              Hi Loup,
                              Are you saying that you are using HomeSeer version 2.5.x.x on a Windows 7 PC now and you still get an error containing "WriteLogEx"?
                              This cannot be good!
