Contacting HomeSeer This Week
See more
See less
(resolved) Unable to add users in Emotion
  • (resolved) Unable to add users in Emotion
    Whenever I try to add a new user (clean install, first time adding a user), I get an error stating that an unhandled exception has occurred, and that an Index was out of range. Below is the full exception text:
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
    Parameter name: index
    at System.ThrowHelper.ThrowArgumentOutOfRangeException()
    at Emotion.Emotion.CheckSelectedStatus()
    at Emotion.Emotion.AddItemToListView()
    at Emotion.Emotion.btnAdd_Click(Object sender, EventArgs e)
    at System.Windows.Forms.Control.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnClick(EventArgs e)
    at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
    at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
    at System.Windows.Forms.Control.WndProc(Message& m)
    at System.Windows.Forms.ButtonBase.WndProc(Message& m)
    at System.Windows.Forms.Button.WndProc(Message& m)
    at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(M essage& m)
    at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Mes sage& m)
    at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.261 (RTMGDR.030319-2600)
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Emotion
    Assembly Version: 1.7.5.0
    Win32 Version: 1.7.5.0
    CodeBase: file:///C:/Program%20Files%20(x86)/HomeSeer%20HS2/Emotion.exe
    Microsoft.VisualBasic
    Assembly Version: 10.0.0.0
    Win32 Version: 10.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
    System
    Win32 Version: 4.0.30319.261 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    Win32 Version: 4.0.30319.233 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Win32 Version: 4.0.30319.235 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    System.Drawing
    Win32 Version: 4.0.30319.1 built by: RTMRel
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    System.Runtime.Remoting
    Win32 Version: 4.0.30319.1 (RTMRel.030319-0100)
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Accessibility
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
    System.Speech
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Speech/v4.0_4.0.0.0__31bf3856ad364e35/System.Speech.dll
    HomeSeer2
    Assembly Version: 2.1.0.0
    Win32 Version: 2.2.0.67
    CodeBase: file:///C:/Program%20Files%20(x86)/HomeSeer%20HS2/HomeSeer2.DLL
    Scheduler
    Win32 Version: 2.5.0.49
    CodeBase: file:///C:/Program%20Files%20(x86)/HomeSeer%20HS2/Scheduler.DLL
    w5a0kqqh
    nvm1wvq0
    tto4nipa
    HS2Util
    Assembly Version: 1.0.0.0
    CodeBase: file:///C:/Program%20Files%20(x86)/HomeSeer%20HS2/HS2Util.DLL
    System.Web
    Win32 Version: 4.0.30319.272 built by: RTMGDR
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/System.Web/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Web.dll
    HSPI_EMOTION
    CodeBase: file:///C:/Program%20Files%20(x86)/HomeSeer%20HS2/HSPI_EMOTION.DLL
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT debugger registered on the computer
    rather than be handled by this dialog box.
    Anyone have any ideas?
    Thanks in advance!
    Hi Nikku,
    We have tested your scenario and confirmed this to be a bug.
    We are working on a fix and will get a solution to you later today.
    Oops - Sorry about this!
      Originally posted by Emotion View Post
      Hi Nikku,
      No problem, glad I could help discover the bug
      Thanks for your help!
        Hi Nikku,
        Please find attached file.
        To update an existing Emotion v1.7.5.0 installation:
        1. Ensure you Quit from Emotion if it is running
        2. Make a backup copy of Emotion.exe located in C:\Program Files (x86)\HomeSeer HS2
        3. Extract Emotion.exe from the zip and place it into this folder
        4. Start Emotion
        Please can you give this a quick test. We have regression tested this. It works for us but then we're developers so we would say that!
          Hi Nikku,
          4. Start Emotion
          I'm unfortunately at work right now, so I can't test it right this instant (if I was anywhere else I'd hop on my VPN, but our firewalls block that )
          I'll be sure to test it out immediately when I get home and notify you of the results, as it's the last part of my newest upgrades to my systems! Just put in automated locks and the bluetooth connector as well, I'm looking forward to integrating the Emotion plugin with it all
          Again, thank you for your speedy assistance!
            No problem Nikku - we're more than happy you notified us of the bug in the first place!
              Just an update, looks like that fixed the problem!
              Thanks again!
                Excellent - thank you!
                  Please see v1.7.6 which addresses this issue.
                  Details here: http://board.homeseer.com/showthread...83#post1010183
