Hey guys, finally got around to ordering my automation module so I can put it in and set this plugin up and wanted to have some of you who have done this before double check me and make sure my install plan is correct.
1. Turn off power to the alarm panel, it is connected to power in the attic so I am going to pull that.
2. Unplug battery and insure that nothing is still powered
3. Connect the new 4-22 wire that I ran to the +12V, Bus A, Bus B and GND terminals on the main panel
4. Connect the same wires to the corresponding terminals on the Automation Module
5. Hook up the automation module to my Quatech serial server
6. Plug in the alarm power and hook up the battery
7. Enable the plugin in HS and test communications
Am I missing anything or is there a better order to do this?
I am not that experienced with alarm setup and installations, so I am looking to the Collective for a little help and direction!
