When I first saw this plug-in, I thought all my problems were solved. I had been using Webcam32 and had to use macro magic to change the modulated channels by closing Webcam32, opening WinTV, changing the channel, closing Wintv and reopening Webcam32. This was an absolute pain, and didn't always work correctly. What a brilliant idea for this plug-in!!!!! The description met everything I was looking for and what other software lacked
I was all set to get rid of everything, but unfortunately, I still haven't been successful in getting it to work.
My initial problem was that I would just get a blank screen when I loaded the preview. This was solved by downgrading the drivers.
My current problem is that the plug-in will not take any pictures. When I load the preview initially, I see all snow, but if I hit Channel up, and then Channel down, the picture shows perfectly. If I select the camera from the drop down, it will not work, it just shows snow. I've tried almost every version of the drivers that I could find (from 327xxx to 335xxx, but still no luck.
I would gladly pay twice the plug-in fee to get it to work!!! I noticed this is similar to issues others are having as well, but I have not seen a resolution posted. I'm hoping this plug-in is alive and well and doesn't die!
I will gladly buy a new card if it appears that it may be the issue, but I'm curious on how many people have gotten this to successfully work so far? And those who haven't, what is the issue you are experiencing? I know the driver downgrade will solve most.
Here are some stats:
Windows 2000
Homeseer 1.6.115
Prodinfo on Card:
Model 44371 Rev. B123
Serial #4086004
Tuner Formats: NTSC (M)
Tuner Audio: Stereo (MSP3435)
Video Formats: NTSC ( M 443 ) PAL ( B G H I D K M N NCOMBO ) SECAM ( L L' )
Audio Outputs: Internal and External
External Inputs: 2
S-Video Inputs: 1
Teletext: Yes (Software)
Radio: FM
Decoder: BT878
Tuner Model: Philips FM1236
EEprom Contents:
84 12 00 00 05 50 0e 7f 08 17 23 53 ad 93 14 89 00 00 00 00 05
84 0a 00 01 01 20 77 00 40 f4 58 3e 00
74 02 01 8a 03
79 a3
Exec.exe 2.6.21026
Hcwclear.exe 2.57.21087
Primary.exe 3.7.20154
Prodinfo.exe 1.8.21050
WinTV2k.exe 3.52.21079
hcwChan.dll 3.19.21126
hcwTVDlg.dll 3.15.21126
hcwTVWnd.dll 2.110.21125 DS-PVR
hcwHook.dll 1.5.17117
hcwSnap.ax 1.12.21077
hcwDlace.ax 1.1.0
hcwsnbd9.dll 9.0.0
gear32sd.dll 6.2.0
hcwWintv.ocx 2.00.9235
wtvcap.ocx 1.1.19214
ChSuite.ocx 1.6.19214 0
hcwutl32.dll 3.7.21048
hcwi2c32.dll 2.2.18123
hcwpnp32.dll 4.5.21050
btgpio32.dll 1.6.17148
bt848wst.dll 4.2.20296
msvcrt.dll 6.10.9844.0
msvcirt.dll 6.10.8637.0
msvcrt20.dll 2.12.000
msvcrt40.dll 4.20 - OS use only. DO NOT DISTRIBUTE
mfc42.dll 6.00.9586.0
Hcwbt8xx.sys 3.35.21093
Windows 2000
Homeseer 1.6.115
Prodinfo on Card:
Serial #4086004
External Inputs: 2
S-Video Inputs: 1
Radio: FM
Decoder: BT878
EEprom Contents:
74 02 01 8a 03
79 a3
Exec.exe 2.6.21026
hcwDlace.ax 1.1.0
hcwsnbd9.dll 9.0.0
gear32sd.dll 6.2.0
